Guest GalacticDad
Empty/white areas are printing with a slight tint
Guest GalacticDad
Just trying to figure out why the empty/white areas of an image are printing with a slight tint. I'm using the Versaworks save-to-pdf procedure, and printing/cutting on a Roland VersCamm SP-300V thru VersaWorks. Thanks!
If you put a color and  your setup is sensitive enough, it will try to print whatever shade of white it thinks it sees. If your material is white and just want that to show through, then you need to set those parts of your design to be transparent.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
