cub man
Help cutting a image file
So I have been given a image file that has shading in it.  For example the font starts out dark grade, fades to just a light gray with outline back to dark gray.  When i import it into vinlymaster it wants to add several colors.  What is a easy way of doing this.
Post the file if it is not copyright protected, so someone can look at it. But you should be able to grab the whole design and change it to 1 color. If that's what your going for.
Are you talking about trying to do an auto trace on it and the program can't decide what goes where? For one, If it's a font then you won't like the trace results on a font anyway. We all tend to find the correct font and rebuild that part using the actual font. Tracing text never come out clean. (and that's not an exaggeration). For the rest, the best you can do is import it into a rastor image program like Gimp or PS and manipulate it to a solid black and white. I usually just hand trace all things anyway (but still not text unless I can't find the font) Auto trace does not get it precise enough for my taste in most cases.
Always best to find the font and recreate the design. Thought you only had like 1 font.   As stated above. fonts don't trace well.   Find the fonts. Many programs out there to match fonts. Even if you attempt to trace them, you will have to node edit them.
55 minutes ago, cub man said:
This is the file.. Want to scan so all fonts are gray
That file might be png, but I bet there is a vector version somewhere.  If not, I bet there is a native file version like a photoshop file.  That would be better to have as it would still preserve fonts and might have real shapes.  Even better if it is an AI file.  Ask them for the source file.
Guest
Reply to this topic...
  Only 75 emoticons maximum are allowed.
Loading...
