Tracy Taylor 0 Posted April 11, 2018 I desperately need instructions on accessing glyphs and swashes in certain fonts using my VM Cut and Windows. On my Mac I used Fontbook. Thank you in advance!! Quote Share this post Link to post Share on other sites
darcshadow 1,626 Posted April 12, 2018 I believe someone posted a question along these lines once before so a search might find a VM specific answer, but a general answer would be to use the Windows Character Map program/app to select the character you want then copy and paste into VM. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted April 13, 2018 If you have PRO or above you can insert them using this tool: Else, use Alt+ and then enter the code, so for example if you wanted a pound symbol, click in text mode in the design area, hold the Alt button and type 0163 and £ will appear. 0128 for a € etc. See this site for more detail: |http://cloford.com/resources/charcodes/ms-symbols.htmhttp://cloford.com/resources/charcodes/ms-symbols.htm Quote Share this post Link to post Share on other sites
southernshoreso 0 Posted February 2, 2019 I have Pro and I do not have the option you are showing to get to the extended character set. Where do i get that to show? Quote Share this post Link to post Share on other sites
haumana 1,220 Posted February 2, 2019 7 hours ago, southernshoreso said: I have Pro and I do not have the option you are showing to get to the extended character set. Where do i get that to show? You need to actually start to type something, then the Omega symbol will appear on your toolbar. Quote Share this post Link to post Share on other sites
