twentythreemx 3 Posted March 1, 2018 So I've had an MH series cutter for a few years now, have printed thousands of decals from it. I had the opportunity to get a good deal on a used SC...and larger. (50 vs 30). Well, THOUGHT it was a good deal. I got it and found out it was NOT the SC2 that I thought, rather an older SC. SO i have a few questions, and i tend to talk too much so, apologize when this gets wordy....bare with me! 1. First off, am I better off sticking with my MH 871 mk2 than the SC ?? The MH I notice goes much lower in speed and different increments, compared to 100/200/300 etc on the SC.. is the SC a better machine still even if older? 2 Secondly I did some tests.. I'm getting a lot of jagged lines on just like a letter A for example. I did a square test and corners are good, I dont think the offset has anything to do with it, tried 25 and 30 and didnt notice a difference. I put in a new 45* blade. I usually ran my MH speed around 160. I turned on this SC and saw the speed was set at 600, holy crap! Looking online it seems common people run them 300-400 or higher no problem. I turned my speed down to 100 and the lines come out FINE. 200 they come out 90% but almost look a little fuzzy. 300 and they are starting to get pretty obviously wavy. What is causing this wavyness? I played around with blade height, I felt like it was too far out. Its barley visible and passes the "cut a piece by hand" test.. but again i see post of people running pressure 40 or much less. that barley cuts for me. i had to set pressure up to like 160, and it seems to weed fine, barley leaving marks on the backing. but why the need for so high? should i poke the blade out more and decrease pressure or is it "whatever works" kinda combination? Im just concerned for small stuff, and also want to make sure i didnt get a broken/worn out unit. 3. i read about jagged edges maybe being caused by needing an adjustment of the belt tension, is there a way to test that? this thing is used but i dont think it has too many cuts ran through it. im really interested in being able to get those 300-400 speeds, compared to running at 160 on the MH that will be super nice to get things moved through a little quicker.... but not at the price of horrible cuts. Its 100% not my design, ive cut hundreds of them. but clearly im missing a magic combo of settings / blade height or that belt is loose or something. anyone got any ideas on how i can get it dialed in? ive searched allover and watched the setup video... throwing in the towel, help! Thank you!!!!! Share this post Link to post Share on other sites
twentythreemx 3 Posted March 1, 2018 also could it be a driver issue? i would guess no because its communicating fine.. baud set at 9600 in sure cuts a lot. i notice though that the driver shows up in windows 7 as usb device rather than a printer. I downloaded the drivers from the uscutter site, attempted to install. honestly not sure if it did anything or not. sure cuts a lot picked it up fine before and after. possibly the SC and MH are using same driver??? Share this post Link to post Share on other sites
