jskwarek 13 Posted February 20, 2018 Wasn't sure if I should put this post in the hardware forum or software but figured I'd start here as I think it might be settings on the software. I have an LPII and use SCALP to send my files to cut. I've noticed since day one that if I send a cut, say a circle that the circle does not get cut completely. There's always a little "tag" where the cut wasn't complete causing weeding to be a nightmare. I recently did a large job that was a lot of letters and it was a nightmare to weed because the letters were small and these little "tags" were causing me to lift the letters while weeding. Is there a setting in the SCALP software that I can look at to try and attempt to resolve this issue? Thanks in advance, for any advice. Jason Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 20, 2018 look for a feature called overcut in the cutting portion of the software (NOT OFFSET - different ) overcut will have the cutter go just a bit past the end to make up for the slight tag a lot of stepper motor cutters leave. pretty sure scalp has it - I know vinylmaster, flexi etc have it in the cut sections Share this post Link to post Share on other sites
jskwarek 13 Posted February 20, 2018 That's what I was looking for. I'll take a look as soon as I'm back in front of my machine. I think I saw that setting. I tried messing with Offset and just made things worse. HA! Thank you! JS Share this post Link to post Share on other sites
darcshadow 1,625 Posted February 20, 2018 I just happened to post about over cut and blade offset just the other day. See the referenced post for examples of over cut settings. 1 Share this post Link to post Share on other sites
jskwarek 13 Posted February 20, 2018 Thanks Darcshadow. Just found the post, digging around in the forums. Appreciate the feedback. Share this post Link to post Share on other sites
