I'm sure someone with SCALP experience will chime in. In the mean time - is there a weld, or punch through feature?
Group the four white objects together, then place them over the black where you want them. Select all the objects (black and white pieces) and then right click, paths and then back minus front.
If you merge the two then the white parts outside of the keystone will appear black and the parts inside the keystone will be clear as with the back minus front.
Donn
You only want white and black? If you add some color this looks pretty good I think.
