Guest Sean Posted February 4, 2018 How do i break the coffee cup out and put coffee spelling instead then hill it all together like the cup is vinymaster pro Quote Share this post Link to post Share on other sites
haumana 1,035 Posted February 4, 2018 Are you hoping that that the Coffee text also has the EKG effect, or do you just want to just swap out the location of the cup with the text? Post the file. Quote Share this post Link to post Share on other sites
crome 53 Posted February 5, 2018 Create a square and place it on top of the coffee cup, then select both images, right click, shaping and then punch out. create your text, place it where you want it, select both objects, right click, welding, weld selected. Or you can select your image, select the eraser tool and just erase the cup. Hold down the left click button to use the eraser, the right button will add fill. Quote Share this post Link to post Share on other sites
Guest Sean Posted February 5, 2018 Thank you very much got it Quote Share this post Link to post Share on other sites
darcshadow 1,440 Posted February 5, 2018 One suggestion from a design standpoint, I'd use a script font so that the heartbeat line flows as one continuous line. 2 Quote Share this post Link to post Share on other sites
Primal Decals 621 Posted February 5, 2018 54 minutes ago, darcshadow said: One suggestion from a design standpoint, I'd use a script font so that the heartbeat line flows as one continuous line. I agree completely. Quote Share this post Link to post Share on other sites
