Guest Sean
Need help
Guest Sean
How do i break the coffee cup out and put coffee spelling instead then hill it all together like the cup
is
vinymaster pro
Are you hoping that that the Coffee text also has the EKG effect, or do you just want to just swap out the location of the cup with the text?
Post the file.
Create a square and place it on top of the coffee cup, then select both images, right click, shaping and then punch out. create your text, place it where you want it, select both objects, right click, welding, weld selected.
Or you can select your image, select the eraser tool and just erase the cup. Hold down the left click button to use the eraser, the right button will add fill.
One suggestion from a design standpoint, I'd use a script font so that the heartbeat line flows as one continuous line.
  • Like 2
I agree completely.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
