bikemike 711 Posted January 19, 2018 30 minutes ago, darcshadow said: The problem with just subtracting is it is only correct if your design has equal height and width. If for example the design in your example was only 0.41" tall to start with now it's height is 0. The correct height for the new width should be 0.35. You need to shrink the height by the same percentage as the apparent width shrank. So in your example the actual width is 2.83, the perceived width is 2.42 so that a change of 85.5%. So shrink the height by the same percentage and the image should then look correctly, when viewed straight on. Actually, it is a 14.5% shrink in the height. That would get our numbers a LOT closer than the subtraction. As in the same numbers. 1 Share this post Link to post Share on other sites
bikemike 711 Posted January 19, 2018 I have changed the calculations in my post. Thanks to darcshadow for the input and his calculations. Hopefully, one way or the other you will be able to work it out. 1 Share this post Link to post Share on other sites
Go-C Graphics 856 Posted January 19, 2018 WOW!!!!!! Ya'll are going DEEP................... I just add about 12% to the width when I'm dealing with a shape and I've never had a customer complain. 1 Share this post Link to post Share on other sites
darcshadow 1,626 Posted January 19, 2018 I need to re-look at my equation from the other post, I think it maybe a bit off now. One other thing to think of, using a percentage coverage might not be the best method. It gives you the max width for your image, but if your image is tall, when you resize it tot he calculated width it might be too tall for the glass. Share this post Link to post Share on other sites
bikemike 711 Posted January 19, 2018 1 hour ago, darcshadow said: I need to re-look at my equation from the other post, I think it maybe a bit off now. One other thing to think of, using a percentage coverage might not be the best method. It gives you the max width for your image, but if your image is tall, when you resize it tot he calculated width it might be too tall for the glass. No, the height goes down. I think we are all going crazy. Lol. 1 Share this post Link to post Share on other sites
bikemike 711 Posted January 19, 2018 2 hours ago, Go-C Graphics said: WOW!!!!!! Ya'll are going DEEP................... I just add about 12% to the width when I'm dealing with a shape and I've never had a customer complain. And you somehow expect less? We do the best to come up with the simple solution. Lol, big time! 1 Share this post Link to post Share on other sites
darcshadow 1,626 Posted January 19, 2018 1 hour ago, bikemike said: No, the height goes down. I think we are all going crazy. Lol. Ok, re-looked at my equation and I'm still happy with it. Regarding your statement, yeah, the height will go down but if you start with a tall skinny image even after shrinking it down to the desired width it might still be too tall for the glass. 1 Share this post Link to post Share on other sites
bikemike 711 Posted January 19, 2018 39 minutes ago, darcshadow said: Ok, re-looked at my equation and I'm still happy with it. Regarding your statement, yeah, the height will go down but if you start with a tall skinny image even after shrinking it down to the desired width it might still be too tall for the glass. Ya, that's where the "best guess' thing comes in. I think we got everyone in the ball park. So, exact math divided by best guess will get you there. Print your work out, cut it out of the paper and have a look. We got you close, y'all should be good to go. Share this post Link to post Share on other sites
bikemike 711 Posted January 19, 2018 47 minutes ago, darcshadow said: Ok, re-looked at my equation and I'm still happy with it. Regarding your statement, yeah, the height will go down but if you start with a tall skinny image even after shrinking it down to the desired width it might still be too tall for the glass. Your not shrinking the width, you are shrinking the height. Tall and skinny should not have much of an effect anyway. None of this math is set in stone. You still have to play a bit. Share this post Link to post Share on other sites
spiffygriffy98 0 Posted September 28, 2020 Okay, so math is NOT my strong suit (terrible thing for a designer and vinyl shop owner lol). I'm having some issues working with a tapered pint glass and a circular logo. I've done my best to follow the basic equations y'all have shared, but it still comes out looking incredibly squished and uneven. Any suggestions? Share this post Link to post Share on other sites
darcshadow 1,626 Posted September 28, 2020 You have to account for two distortions, and the image will always look a little off if you're not looking at it exactly straight on. First you need to account for the curve of the glass. Since glass is an inverted truncated cone use the diameter of the cup about where the middle of the design would be. Easiest way to do that would be to take a string and wrap it around the cup where the design will be, that will get you the circumference. Divide that number by Pi, 3.14, to get the Diameter to use in the equation below. H = h/w*D*sin(w/D) h - height of image w - width of image D - diameter of cup H - new height for image And here is a discussion on how to account for the tapered shape of the glass which includes a spreadsheet to do the math so you can create a template. Even with all this, there's still can be a bit of experimentation to get the design perfect but I've been pretty pleased with my results. 2 Share this post Link to post Share on other sites
spiffygriffy98 0 Posted September 29, 2020 On 9/28/2020 at 11:33 AM, darcshadow said: You have to account for two distortions, and the image will always look a little off if you're not looking at it exactly straight on. First you need to account for the curve of the glass. Since glass is an inverted truncated cone use the diameter of the cup about where the middle of the design would be. Easiest way to do that would be to take a string and wrap it around the cup where the design will be, that will get you the circumference. Divide that number by Pi, 3.14, to get the Diameter to use in the equation below. H = h/w*D*sin(w/D) h - height of image w - width of image D - diameter of cup H - new height for image And here is a discussion on how to account for the tapered shape of the glass which includes a spreadsheet to do the math so you can create a template. Even with all this, there's still can be a bit of experimentation to get the design perfect but I've been pretty pleased with my results. Thank you! This helped a lot. It’s not 100% perfect, and idk if it ever will be, but it’s a thousand times better than it was!! Share this post Link to post Share on other sites
