A51graphix 0 Posted January 13, 2018 Can’t find any reviews. Anyone use one.? Like dislike. Looks to be well. Worth the money 399 with a Servo motor ?????? anyone know what actual brand it is ? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 13, 2018 looks like a saga and interesting red note on their add " *Not compatible with Heat Transfer Vinyl. Designed Specifically for Sign & Sticker Vinyl*" Share this post Link to post Share on other sites
A51graphix 0 Posted January 13, 2018 Is heat transfer thicker or something ? This is all new to me I’ll be doing race stickers and signs anyway Share this post Link to post Share on other sites
Cal 393 Posted January 13, 2018 That sounds like a heck of a deal on a servo machine. Some conflicting info on their web site. This in the product description: Whether you're working with heat transfer vinyl or adhesive sign vinyl, the Vinyl Systems Evo will get the job done like no other. While this is in the Q&A section: Q: Good morning, why this machine isn't compatible with heat transfer materials? I saw it on eBay. Vinyl Systems Evo 28" Cutter Plotter - Contour Cutting DC Servo Motor Thank you Posted On: 10/2/2017 By: Robson A: Hi Robson, the Vinyl Systems Evo is an exceptionally powerful cutter that was originally made to cut all types of sign and decal vinyl as quickly and efficiently as possible. With its powerful servo motor, we noticed when tracking heat transfer vinyl, it could potentially fold a bit due to how thin the material's backing is. You can still cut heat transfer vinyl with this cutter but we would recommend using a cutting mat for a large design. Sign and decal vinyl already has a backing that is able to feed the vinyl back and forth without any issues so therefore, we would consider this cutter to work flawlessly on decal vinyl without any additional supplies. Cal Share this post Link to post Share on other sites
slice&dice 2,450 Posted January 13, 2018 What drives me crazy is that none of these Chinese manufacturers provide a 34" (870mm) sized machine with servo motor. Go to alibaba, and you'll see what I mean. Share this post Link to post Share on other sites
