da5id
Cutting paper and card stock
Hi there,
I'm using a Titan 3 to cut paper and card stock and I'm having trouble finding a good carrier sheet. I got some adhesive ones of Graphtech and they were so tacky that the paper stuck to them, ruining both the paper and the carrier sheet. I then tried some Saga cutting sheets, and the same thing happened, ruining both. Do y'all have recommendations on a good setup for feeding paper through the cutter?
What about this stuff?  Available at walmart.  (says it is 'repositionable')
d4f6935d7b79e5498af6236d9eb60c4e--dream-
Good suggestion. It may work, but I worry that it'll leave tacky residue on the backside of the paper. I should try it though.
Well, some residue will indeed remain, so while you are already at walmart, buy some of THIS --
Solution so far has been to mount paper onto a large, thin cutting board (purchased from a cooking supplies store) with drafting tape all around the edges.
I have a Cricut cutting matt and experienced similar concerns as you about too sticky. I basically dirtied mine up until it wasn't so bad. A little lint and dust did the trick.
  • Haha 1
