hi guy hope someone can help before I pull all my hair out
I have a pcut cs630 and I'm using flexi 10 software after installing this on a windows 10 computer every time I send to plotter the carriage shoots to the left until it hits the cut out switch.
I have checked baud rate is 38400 and its running on com 3
Are you absolutely certain the 38400 is the correct baud rate? I have not had my P-Cut for several years but that seems off.
Should be 9600, I do believe
On 10/01/2018 at 6:41 PM, bonkingbilly said:
hi guys changed it to 9600 in flexi and com settings now it just says on the cutter "working com-connection" when I send but no movement from the head
bonkingbilly did you ever get this sorted out? I have the exact same problem with the 'working com-1 Connection'.
