Drock 0 Posted May 13, 2008 I am still pretty new to sign cutting, and was curious if someone could elaborate on the art of Wet Application. for example, when is the best time to do a wet app. what can you use for the "wet stuff", how long do you need to leave it on before you peel off the mask etc... any suggestions would be great! thanks Droc Share this post Link to post Share on other sites
Benr98 40 Posted May 13, 2008 Here are a few links I found that may help you out. Jenny http://forum.uscutter.com/index.php/topic,2074.0.html http://forum.uscutter.com/index.php/topic,5905.0.html http://forum.uscutter.com/index.php/topic,1521.0.html http://forum.uscutter.com/index.php/topic,1034.0.html http://forum.uscutter.com/index.php/topic,1113.0.html http://forum.uscutter.com/index.php/topic,3302.0.html Share this post Link to post Share on other sites
Drock 0 Posted May 13, 2008 thanks, that was very helpful! Very interesting, I have been doing dry applications the whole time and had no idea that wet applications are so much more forgiving. thanks again Droc Share this post Link to post Share on other sites
firemalt 10 Posted May 13, 2008 I've gotten to the point where I use the wet app for almost everything, lol. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted May 13, 2008 I've gotten to the point where I use the wet app for almost everything, lol. You and me both. Life is too short and I am too old to waste time. Share this post Link to post Share on other sites
CyberSultan 6 Posted May 17, 2008 Did some graphics on my car today...and decided to try it wet. I will never do car graphics dry again! No bubbles, easy to position just perfectly, and the basic components of the wetting solution, I got from this forum, worked great (easy to squeegee and took only a few minutes before I could remove the app tape). Then applying a second layer of color was just as easy. I only needed a little solution, so I mixed: 16 oz water 2 Tbs Rubbing Alcohol 4 drops of dish soap This solution worked perfect! Share this post Link to post Share on other sites
showaride 0 Posted May 17, 2008 glad wet app works for you guys. I cant say the same, I mixed like posted here but I cant get the fluid out. scrape like crazy but doesnt work. Still have fuild under the vinyl. using a normal scraper. Share this post Link to post Share on other sites
firemalt 10 Posted May 17, 2008 Are you using clear app tape? Share this post Link to post Share on other sites
Guest Terry Posted May 17, 2008 sure sounds like it, I even spray the front of the tape till it almost falls off on it's own. But I try not to get wet on door jam edges. I like it to grab a bit quicker in those areas. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted May 17, 2008 I agree. He/she is doing something wrong. Maybe not using the right type of squeegee? Share this post Link to post Share on other sites
Guest Terry Posted May 17, 2008 Yup, one thing I do is at the top of the graphic I wipe it down so the fluid does not keep running down the car under the tape or vinyl. Share this post Link to post Share on other sites
showaride 0 Posted May 17, 2008 I was doing it on a cars back window. I had one of those white plastic ones I been using with normal cream or whatever transfer tape. I thought I had the fluid out, spent 10 to 15min then spread the tape to losen and still want to come up because the fluid was under vinyl still. Does it help to add more alcohol to mix to dry faster? What tools should I use for the curve? Thanks guys! Share this post Link to post Share on other sites
firemalt 10 Posted May 18, 2008 I agree. He/she is doing something wrong. Maybe not using the right type of squeegee? He should of used a "gold" squeegee, LOL. Share this post Link to post Share on other sites
showaride 0 Posted May 18, 2008 I agree. He/she is doing something wrong. Maybe not using the right type of squeegee? He should of used a "gold" squeegee, LOL. Do the gold squeegees cure more? How about using a window squeegee? would that work. Dont want to was anymore vinyl. Share this post Link to post Share on other sites
BannerJohn 1,324 Posted May 18, 2008 what are you using now? Share this post Link to post Share on other sites
showaride 0 Posted May 19, 2008 the basic white one. I dont see what the difference is with the other ones. What is best for doing curve apps like cars, backwindows and show on? Share this post Link to post Share on other sites
keith2j 0 Posted May 20, 2008 Did some graphics on my car today...and decided to try it wet. I will never do car graphics dry again! No bubbles, easy to position just perfectly, and the basic components of the wetting solution, I got from this forum, worked great (easy to squeegee and took only a few minutes before I could remove the app tape). Then applying a second layer of color was just as easy. I only needed a little solution, so I mixed: 16 oz water 2 Tbs Rubbing Alcohol 4 drops of dish soap This solution worked perfect! This worked great thanks. Keith Share this post Link to post Share on other sites
Drock 0 Posted May 21, 2008 wow that gold squeege sounds nice! how do I get one? does it come hydrated or something? lol droc Share this post Link to post Share on other sites
