Dakotagrafx 7,297 Posted January 6, 2018 import this and try it test.eps Share this post Link to post Share on other sites
bonsey 1 Posted January 6, 2018 I tried a different font (Amazone BT) within LXi , same effect. Also tried creating the letter in Photoshop, saving it as PNG, converting to SVG file and importing, still same effect. I have a message in to SW tech to see what they say. Share this post Link to post Share on other sites
bonsey 1 Posted January 6, 2018 Same effect with your test file, except it seemed like it double or triple cut each line.. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 6, 2018 has to be a communication or plotter issue then Share this post Link to post Share on other sites
bonsey 1 Posted January 10, 2018 Just in case anyone else experiences this issue, I seem to have found the solution. On the cut/plot screen of LXi, there is a "Properties" button near the top left underneath where it lists your plotter and the COM port. Click on properties. There are 3 tabs that appear. Click on the 3rd tab on the right or the "Cut" tab. On that tab there is a "Curve Quality" setting. Mine was set to "Custom" or .040". I set it to "High" and now my curves come out completely normal. 1 Share this post Link to post Share on other sites
