I am wondering if there is a way to get my printer to cut in order of the vinyl... instead of jumping all around cutting here then there then back to here...the cut would be completed quicker if I can get it to cut in order.. I do have Vinyl Master Pro
Thanks
Printing?  Sounds like your cutting, with your vinyl "cutter"   The cutter is not a printer.unless your using a pen tool, then it's a plotter. . .. Unless your software has a step by step cutting function, or another name (optimize cutting order,)  then no. that is how a vinyl cutter works. Step by step cutting would not be advised for detailed designs.
Are you having problems with vinyl tracking?   You do not mention which vinyl cutter.
I was looking at Vinyl Master Pro demo  and  after clicking  SPOOL ALL>Preview,, on the right side bottom you can check  REDUCE TRAVEL..   That may or may not help you,  because doing that also uses up a lot more memory,And those MH cutters are very limited on memory.
your welcome
  • Thanks 1
12 hours ago, ExposeURDesigns said:
That was it thanks man I really just cut my time in half
Wow!
You might look into A. upping your cut speed B. reducing the number of nodes in your designs and C. make sure you are not cutting any part of the design a second (or third) time.
As an example, a circle or oval shape can be cut with 4 nodes.  Any more than that creates extra "work" for the cutter.
And welcome aboard, glad to have you here,
Oh, one last thing, Ms Skeeter is a lady:D  and a real helpful one at that!
Cal
5 hours ago, VinylMaster said:
You can set the cutting order here and even watch a preview of the cutter's blade cutting:
What am I missing?    I've never seen those buttons before in my VM and I have both PRO and DSR versions
50 minutes ago, VinylMaster said:
You can download the program at any time from the original webpage you were given. These sites are updated all the time.
Thank you.....  Got it.
Are the "Install_Extras" updated also?   Should I download that again too?
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
