aguilar
Pc 50 Printing error
Well, most likely needs a new printhead which are nearly impossible to find and if you do find one it will likely cost more than the machine itself is worth.
Most people only use these as cutters once the printhead goes bad.
I found something near the printing head area   don't know if is vinyl material stuck ( the yellow thing barley  showing) or something like a sensor
Try and print a simple graphic in black, that will tell you whats going on.
Need to clean the head after each print session.
Forget the cleaning pencil, I use roland sovent cleaner and swabs. PC-60
mark-s
Ok so I send something to print and it work great , but after it finish the ribbon got stuck, so I will be disassembling the head and manually lifting the head
