Chriscarp746 6 Posted November 24, 2017 Can someone explain to me what sublimation is? I'm looking to do shirts in HTV with a heat press to start out. Is sublimation something I need a crash course in to just start out? Thanks Share this post Link to post Share on other sites
slice&dice 2,450 Posted November 24, 2017 In one word, it's Full-Color Printing (using special inks called Dye-Sublimation). If you want to experiment with T-shirts, it's easy enough using a cutter and instead of regular vinyl, just substitute HTV. So, after cutting & weeding, place the decal onto the material and the Heat Transfers the Vinyl onto the cloth. No printing involved. Share this post Link to post Share on other sites
Chriscarp746 6 Posted November 24, 2017 Thanks slice, that pretty much answers my question. Share this post Link to post Share on other sites
bikemike 711 Posted November 24, 2017 51 minutes ago, slice&dice said: In one word, it's Full-Color Printing (using special inks called Dye-Sublimation). If you want to experiment with T-shirts, it's easy enough using a cutter and instead of regular vinyl, just substitute HTV. So, after cutting & weeding, place the decal onto the material and the Heat Transfers the Vinyl onto the cloth. No printing involved. You forgot. REVERSE IMAGE WITH HTV!!!!!!!! 1 Share this post Link to post Share on other sites
slice&dice 2,450 Posted November 25, 2017 You are welcome. Just for clarification, bikemike was referring to the cut-manager software setting when cutting (called "mirror" in my program of choice, SignBlazer) I understand that you are just starting out --- make sure you have plenty of room for work area. Keep it neat and tidy, as things get out of control fast if you don't. One item that's great to have is a utility tray/carrier (Sterlite makes a good one for about $6) for all the little things like knives, weeding picks, measuring tapes, 12" rulers, scissors, gooGone (citrus-based adhesive remover), masking tape, markers, etc. Share this post Link to post Share on other sites
