Tommygirl 0 Posted November 18, 2017 Hi can some please tell me how or what setting i should use to cut - Plastic stencil - thanks Share this post Link to post Share on other sites
slice&dice 2,450 Posted November 18, 2017 If you are using a cutter designed for very thin vinyl ( 70 microns ) with backing paper, then that's what it is designed for, not to die-cut through hard plastic. Also, letter stencils need to be done with specific fonts that have 'bridges' to connect the inside portions (islands). For instance, the letter O. Share this post Link to post Share on other sites
