MrJoel
Solved***Circles not closing, cuts slightly off, flags, tad...solved
I’ve have this Laserpoint 2 since July and you can go back and look at the issues I’ve had... my offset was never quite perfect, and the overlap was causing issues sometimes leaving little .2mm slices into the design that sometimes causes a catastrophe when weeding.  Then I ran some simple rectangles and found out (after $30 of Reflective was cut undersized) that my scaling was off.  On a 1” square it was off.. it was .96x.97”.  It doesn’t seem like much but when I recalibrated it in the software, all the other issues went away.  This should be a test you run when you get your cutter or you are having problems.
