Martha Moy 0 Posted October 23, 2017 It cuts very erratic. Doesn't cut to deep. It just doesn't cut the pattern right Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 23, 2017 You have not provided any info to help you. No mention of computer operating system, cutting software. your using, how you are connected to the computer USB or serial.? Was the design a vector or are you trying to cut a jpeg? How did you set your blade depth..? Is this a new cutter to you or a used one? Did it just start like this? or has it being running good and start doing this? Is the cutter grounded to the stand if you have one? It could be many, many reasons including user errors. Not knowing how to set up and operate the machine correctly. 3 Share this post Link to post Share on other sites
