Modtour4
GS-24 help
Had to print something 42" long. Have a roll loaded. Pushed button for roll, Would not print all of the graphic, stopped after about 36"
How do I set it to print something as long as I need?
Thanks for any help.
Russ
Russ, while I don't own a gs and been a while since I had a GX in the shop - generally you have no limitations on length once you select roll  - only when selecting sheet.   what software are you using  - the people on here that might own a gs that might help would need to know all things like that.   You will never get that plotter to print but hopefully we can figure out why you can't cut longer items.
Sorry, didn't mean "print", should have said "cut".
since I see in another post you are using corel draw - are you using cut studio to send to the cutter?  if so there is a screen and tab in that to set width and length -
