ericlecarde
Razorcut spacing between decals. Can this be changed?
Under "Tools" there is a "Weedbox Offset" that controls how big the weedbox is around an image.  I forget what the default is, but I changed mine to 0.05in.
I could swear there is a setting for how much room it leaves between them if you are cutting multiples, but I can't find the setting.
In the cut spooler you can click "settings" and "tight packing" and that will reduce the space between multiple images....but only for this cut. You'll have to reset it each time you go to cut something.
