96mystic
Mh 871 cut size issue HELP
Okay so I'm having a issue with my MH 871 I put all of my measurements in after using my calibration tool then entered them in to the vinylmaster cut when I send the item to cut from right to left then measure and the cut is a 1/8 of an inch off but when I rotate the cut vertical then measure then everything is okay has anyone else had this issue help me please
Make sure the set screws are tight in the grit rollers and that the vinyl is not slipping. Don't mess with the pinch rollers. .  Make sure you have enough vinyl slack behind the cutter, so you are never pulling vinyl from the roll while cutting.   I don't have any more ideas.  It's a bottom of the barrel cutter with a stepper motor.  We always tell buyers to step up to at least the SC..  The SC is more reliable from what others users state. .   I would use a pen in the blade holder on paper until I got it figured out.
