96mystic 0 Posted September 30, 2017 Okay so I'm having a issue with my MH 871 I put all of my measurements in after using my calibration tool then entered them in to the vinylmaster cut when I send the item to cut from right to left then measure and the cut is a 1/8 of an inch off but when I rotate the cut vertical then measure then everything is okay has anyone else had this issue help me please Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 30, 2017 calibrate the cutter in Vinyl Master. Share this post Link to post Share on other sites
96mystic 0 Posted September 30, 2017 did that and had text support help me also and had them come in and calibrate it over my computer the problem still exist Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 30, 2017 Make sure the set screws are tight in the grit rollers and that the vinyl is not slipping. Don't mess with the pinch rollers. . Make sure you have enough vinyl slack behind the cutter, so you are never pulling vinyl from the roll while cutting. I don't have any more ideas. It's a bottom of the barrel cutter with a stepper motor. We always tell buyers to step up to at least the SC.. The SC is more reliable from what others users state. . I would use a pen in the blade holder on paper until I got it figured out. Share this post Link to post Share on other sites
96mystic 0 Posted October 1, 2017 im going to upgrade the the sc and dump this one. issues are killing me Share this post Link to post Share on other sites
