castironrobbie 30 Posted September 26, 2017 Hey ya'll trying out lxi because I can't find my SCAL info. Anyway it's troubling me. The software makes my machine cut over the same lines 4 times and just shreds right through the vinyl. Any advice? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted September 26, 2017 sounds like you have 2 issues than - too much blade exposure (the reason it is cutting thru) and multiple copies of the image on top of each other (guessing you are tracing them) other option on multiple passes is in version 12 in production manager on the third tab you can select how many passes it will cut on the same image for ultra thick material 1 Share this post Link to post Share on other sites
castironrobbie 30 Posted September 26, 2017 6 minutes ago, Dakotagrafx said: sounds like you have 2 issues than - too much blade exposure (the reason it is cutting thru) and multiple copies of the image on top of each other (guessing you are tracing them) other option on multiple passes is in version 12 in production manager on the third tab you can select how many passes it will cut on the same imag Ie for ultra thick material Thanks gonna give it another whirl. It's fine test cutting. No issues with depth then actually cutting a graphic it's just going over and over. Maybe an issue with that particular graphic? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted September 26, 2017 could be that graphic has several layers on top of one another use lxi to make a square and cut it - see if it cuts one or many times 1 Share this post Link to post Share on other sites
castironrobbie 30 Posted September 26, 2017 11 minutes ago, Dakotagrafx said: could be that graphic has several layers on top of one another use lxi to make a square and cut it - see if it cuts one or many times Solved. Totally was an image issue. I changed the file type. It was a simple clip art. Worked like a charm. Thanks man 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted September 26, 2017 Love my Lxi master plus ! 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted September 26, 2017 Told USCUTTER for at least 7 years they need to private label a flexi product like that - they could name it USexi pronounced "you sexi" great product and talk about a marketing buzz with a name like that 4 Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted September 26, 2017 I picked up a legal Flexisignpro 7.5 with dongle and the nice ringed user manual, with the original box and paper work. for $50.00 Buy It Now., the end of July. on Ebay. Seller claimed, needed upgraded. BS.... He didn't know a thing about it. Yeah, it could be, but works fine on Windows 7 32 bit. The design features are worth a heck of a lot more than $50,, 2 Share this post Link to post Share on other sites
