wegotwoodnorthwest 0 Posted September 18, 2017 In need of help. In the last month or so my SC cutter has been making cuts as it travels between cutting images I ACTUALLY want cut. (See pic) Any quick suggestions to help fix this? Thank you! blade depth seems to be fine, all the images I want cut are cut correctly but sliced through when traveling to next image. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted September 18, 2017 You say the blade depth seems to be fine...So how did you set your blade depth?...Many instructions out there say use 1/2 credit card thickness or more, which is incorrect. That is way too much blade exposed. Share this post Link to post Share on other sites
darcshadow 1,625 Posted September 19, 2017 What software are you using, and have you tried something different. The fact that it picks up for the individual letters but then drags to the next word seems like a software issue to me. Share this post Link to post Share on other sites
signyouup 178 Posted September 20, 2017 Vinyl not laying flat as it feeds? Share this post Link to post Share on other sites
cardudenc 151 Posted September 21, 2017 looks to me like blade depth is way too much if its cutting the backing like that. I think static has caused mine to do something similar, but nothing into the backing paper. I tried about every method posted online for setting up blade depth. then came on here and learned the correct way. I'm also using a sc model cutter Share this post Link to post Share on other sites
