Bmfshott 0 Posted September 18, 2017 I have a MH 365 - MK2, which either from the start or midway through a job will stop, click and say test and reset itself. Just started doing it this week after about 2 years of no issues It will periodically work fine, then the next cut do this. I've included a video of what its doing. Seems to be once it gets to the one side it causes it to "test". Anyone had this problem and know the solution? IMG_5152.MOV Share this post Link to post Share on other sites
darcshadow 1,625 Posted September 18, 2017 First guess would be static, although this is not the usual static problem. Does it do it if you use pen and paper? Share this post Link to post Share on other sites
Bmfshott 0 Posted September 18, 2017 I've actually never used the pen on the cutter just the blade. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted September 18, 2017 Ok no pen, so lift the blade holder up so that the blade is not touching the vinyl, and see it it still does it. Run the design again. That could tell if it is static or other problems. Share this post Link to post Share on other sites
Bmfshott 0 Posted September 18, 2017 Ah okay, I will do that when I get home. See if it does that while the blade is up. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted September 18, 2017 Yes, static comes from the vinyl, thru the blade, and to the carriage head. You won't get static with a pen or paper. Share this post Link to post Share on other sites
Bmfshott 0 Posted September 18, 2017 Any ways to eliminate or elevate the static? It's never done this in 2 years. Also thank you for replying and help me trouble shoot this problem. Cutter starting acting up at my busiest time of year Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted September 18, 2017 Spray the area with Static Guard. rub the vinyl with a dryer sheet. If your that busy, time for an upgrade to a better cutter. It may need a new motherboard also.. Share this post Link to post Share on other sites
Bmfshott 0 Posted September 18, 2017 Will do! I was hoping it was a common problem and someone knew the exact cause. If it doesnt work i'll end up buying another one and using this one for "parts" Share this post Link to post Share on other sites
Bmfshott 0 Posted September 19, 2017 So update, used a dryer sheet on the vinyl, didn't have an static guard, but tried the pen out and it still did it. Mid cut goes to test mode, then I tried it several times are went right to test, then half it and back to test. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted September 19, 2017 Did you try swapping out the USB cable for a different one? Is the plug loose? Share this post Link to post Share on other sites
Bmfshott 0 Posted September 19, 2017 Yeah I tried wiggling it while it was cutting to see if that's what causes it but doesn't. Seems to work 1 out of every 12 tries I try to cut. Just gonna order the titan 15" tomorrow. if anyone is looking for a parts one or a fix job let me know I'll let it go for cheap. Share this post Link to post Share on other sites
Bmfshott 0 Posted September 19, 2017 But now it just worked for 4 large cuts haha I dunno, I just don't know what would make it kick into test mode all of a sudden.. may not be a common issue I guess Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted September 19, 2017 after 2 years you are probably going to keep doing vinyl at this point - time anyways to move up a notch - titan is very solid unit from the one I had to the many people on here that use them daily - I know BannerJohn and Pippin both use Titans a lot Share this post Link to post Share on other sites
darcshadow 1,625 Posted September 19, 2017 Might be a loose connector inside some place. Just guessing at this point though. Share this post Link to post Share on other sites
Bmfshott 0 Posted September 19, 2017 I took the top panel off last night and tried connecting everything and pushed in all the connections. Then it worked for a few cuts and I called it a night. So going to see if it acts up again today, going to order the Titan today anyway, just have to convince one of my american friends to order it for me. Not a big fan of not being able to order US Cutter stuff in Canada without a minimum $1000 order and a wire transfer.... Share this post Link to post Share on other sites
