gpau 0 Posted September 7, 2017 Hello, where I can find the MH365 refine uscutter drivers. Before i format my mac the plotter mh365 also worked with mac only that I no longer find drivers who can tell me where to find them? Thank you Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted September 7, 2017 The older Refine MH cutters may have worked for a Mac, but the newer MH cutters do not. so US Cutter does not support the older Refine MH cutters. There is not any Mac drivers at UScutter support. You may be able to do some online searches for a Mac driver..... Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted September 7, 2017 These are the MH drivers that in the support section https://support.uscutter.com/support/solutions/articles/14000030240-mh-mk2-driver-download Share this post Link to post Share on other sites
gpau 0 Posted September 7, 2017 ok, but the uscutter MH365 is old, in the time when I bought the drivers they were. it is possible that they are no longer online? These are the new ones. I do not even know if they are still building this model. The MH365 cutter I had bought in 2012/2013. Share this post Link to post Share on other sites
slice&dice 2,450 Posted September 7, 2017 Buy a used DELL laptop for $60. (preferably one with a serial port) and run your cutter with SignBlazer. 1 Share this post Link to post Share on other sites
darcshadow 1,626 Posted September 7, 2017 If you use the serial port I don't believe you need drivers. The computer just sends the HPGL commands to the plotter using standard communication protocols that all computers should support. If you don't have a serial port you should be able to get a converter that works on macs. Share this post Link to post Share on other sites
signyouup 178 Posted September 7, 2017 1 hour ago, darcshadow said: If you use the serial port I don't believe you need drivers. The computer just sends the HPGL commands to the plotter using standard communication protocols that all computers should support. If you don't have a serial port you should be able to get a converter that works on macs. One of these, works with Mac's. The MH cutters us a "Null Modem" cable. https://www.amazon.com/Tripp-Lite-Keyspan-High-Speed-USA-19HS/dp/B0000VYJRY Share this post Link to post Share on other sites
