BigHE 5 Posted August 25, 2017 Hello. I would like to use my Graphtec 7000-75 to cut shirt vinyl like Siser Easyweed, Stahl's Super Film and printable vinyl like JPSS and Jet Opaque II. So far all I have tied is Jet Opapque II, 11x17. All the cutter does is shoot the vinyl out before I can cut anything. I am not using media or roller sensors. Should I be using a carrier? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 25, 2017 Are you hitting the original button first? How fast are you flying there? I only run between 2-5 speed. No need to fly. If your software is set correctly it will not go any further than what the design is..And it has to be under 11 x17 Move the carriage head to the right corner of the vinyl edge and hit origin button. 2 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted August 26, 2017 also why not use the roller sensor and the sheet setting so ti finds the edges??? Share this post Link to post Share on other sites
arty-rc 719 Posted August 26, 2017 3 hours ago, Dakotagrafx said: also why not use the roller sensor and the sheet setting so ti finds the edges??? Less chance of damaging the cutting strip Share this post Link to post Share on other sites
