steved13
borders with SCALP4
steved13    17
I looked around and couldn't find a tutorial on doing a simple border.  I'm thinking a smaller square within a larger square should work, but is there a better way
security802    678
I usually use to shadow layer (under the effects option) and set the offset that I want. Then you can do shape frames as well, not just rectangle, squares, or circles. Then select both layers and us the merge option to create the frame
Edited by security802
added image
