Dakes2 2 Posted August 3, 2017 I seem to be wasting lots of vinyl cutting my stickers, I have looked at the help files on how to make the tiles smaller, but when I click and drag the tile it just springs back to where it was, if I'm cutting a sticker of say 100mm x 20mm then I have a tile which is cut out also, the sticker sits in the middle with a lot of waist vinyl around it, is there a way of reducing the tile size ? buy the way I cant contour cut these as I cant calibrate my cutter in signcut, using usb Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted August 3, 2017 Is it possible that you are confusing Tiles, with weed boxes? Check the options for weed lines/weed box. Weed boxes usually cut a line around your design..and most software you can change that distance from the design...I don't have Signcut to check that. Just throwing that out there. 2 Share this post Link to post Share on other sites
Dakes2 2 Posted August 3, 2017 Yes, sorry your right, I mean weed boxes Share this post Link to post Share on other sites
