Followers 0
Dakes2
Signcut Tiles
3 posts in this topic
I seem to be wasting lots of vinyl cutting my stickers, I have looked at the help files on how to make the tiles smaller, but when I click and drag the tile it just springs back to where it was, if I'm cutting a sticker of say 100mm x 20mm then I have a tile which is cut out also, the sticker sits in the middle with a lot of waist vinyl around it, is there a way of reducing the tile size ?
buy the way I cant contour cut these as I cant calibrate my cutter in signcut, using usb
Is it possible that you are confusing  Tiles, with weed boxes?   Check the options for weed lines/weed box.  Weed boxes usually cut a line around your design..and most software you can change that distance from the design...I don't have Signcut to check that.   Just throwing that out there.
2 people like this
Followers 0
