Tommygirl 0 Posted July 29, 2017 i been using my cutter at the same setting and cut the same item before but now for some reason it is cutting too deep - but i was watching it cut it seems to be cuting the same area over and over - it keeps coming back the the same area to cut again - why is it doing this? Share this post Link to post Share on other sites
Cal 393 Posted July 29, 2017 Welcome aboard Tommygirl. When you say this is the same item, is it the same file? My first thought is that you have multiple layers going on. What cut program are you using? If you want to post your file up I am sure someone would look at it for you to verify the file is good. Cal 1 Share this post Link to post Share on other sites
Wildgoose 4,200 Posted July 29, 2017 Yeah sounds like you have some duplicate (stacked) items. Some programs will also leave an unfilled/uncolored object in every open hole like the insides of O's etc and you may be re-cutting those items. If you have cut-by-color options in your cutting software make sure you are not cutting more than one color. If it's supposed to be a single color logo sometimes there are hidden white or transparent objects that can be sorted by only selecting the black. Share this post Link to post Share on other sites
