Alex2017 3 Report post Posted July 21, 2017 Hello guys i dont know if im the only one that need it a stand for the 15 inch titan. Here is what i created for under $20 home depot materials I now is not perfect, made my life easier and i just want it to share it in case you guys wants to do something like that 3 Share this post Link to post Share on other sites
Dakotagrafx 6,248 Report post Posted July 21, 2017 I love the design - the only thing I wonder about is how static will dissipate from the vinyl - like the metal stands to metal rollers do - - - - when you read static problems with the mh that is usually the culprit - not sure on the titan though Share this post Link to post Share on other sites
cardudenc 118 Report post Posted July 25, 2017 On 7/21/2017 at 5:40 PM, Dakotagrafx said: I love the design - the only thing I wonder about is how static will dissipate from the vinyl - like the metal stands to metal rollers do - - - - when you read static problems with the mh that is usually the culprit - not sure on the titan though @Primal Decals we was just talking about this the other week. would it be worse or better for the static issue. anyone tried it have any input on the static issue? I definitely like the vinyl rack built in. I have been planning on adding a catch basket and maybe a rack like whats on a graphtec Share this post Link to post Share on other sites
Primal Decals 618 Report post Posted July 26, 2017 @cardudenc yep i remember. I really dont know if it would help or not.I had my own theory but im no static expert lol. To me it would eliminate some static since there is less static carrying material that would be near the floor.. But what do i know lol.. Share this post Link to post Share on other sites
Jburns 232 Report post Posted July 26, 2017 Looks great- for grounding I have ran automotive 12 or 14 gauge wire with the little connectors that are crimped- hard to explain without an image.. but you remove a lower screw on the cutter, sand thru paint- place connector attached to wire - the re-insert screw. Other end of wire goes to grounding source. I have been using these - it's an aquarium grounding probe- connected to your outlet. The prongs are plastic that go in the outlet 1 Share this post Link to post Share on other sites
Dakotagrafx 6,248 Report post Posted July 26, 2017 55 minutes ago, Jburns said: Looks great- for grounding I have ran automotive 12 or 14 gauge wire with the little connectors that are crimped- hard to explain without an image.. but you remove a lower screw on the cutter, sand thru paint- place connector attached to wire - the re-insert screw. Other end of wire goes to grounding source. I have been using these - it's an aquarium grounding probe- connected to your outlet. The prongs are plastic that go in the outlet Actually the cutter itself is grounded thru the 3 way plug on it and that goes to the same place you attached to - but the problem is when vinyl rolling and rubbing builds static and with no metal contact for that the only place to discharge, when a charge gets large enough, is to arc thru the carriage - frying electronics. we haven't seen it much with the titan that most times comes with a metal stand and metal rollers but see it a lot with the MH and SC cutters 1 Share this post Link to post Share on other sites
darcshadow 773 Report post Posted July 26, 2017 USCutter sells a ground strap that hangs from the cutter and lays on the vinyl that would work for you here. You could also just make one, it's nothing more than a wire and some magnets to hold it in place. The key is to ground the vinyl, doesn't really matter if the stand is grounded or not, but with a metal stand it's easiest to ground the stand which then in turn grounds the vinyl that is sitting on it. 2 Share this post Link to post Share on other sites
30-284 86 Report post Posted July 26, 2017 I think I would have extended the legs a little farther for more stability, other wise looks very good! 1 Share this post Link to post Share on other sites
Primal Decals 618 Report post Posted July 27, 2017 check out uscutter for the static string.. http://www.uscutter.com/Anti-Static-Kit-for-Vinyl-Cutters 1 Share this post Link to post Share on other sites
Primal Decals 618 Report post Posted July 28, 2017 On 7/26/2017 at 0:07 PM, 30-284 said: I think I would have extended the legs a little farther for more stability, other wise looks very good! I fully agree, I would be worried of it tipping over with that small spread legs sticking out.. All it would take is 1 fall and you will be buying a new cutter lol. Share this post Link to post Share on other sites
