HOMESTEADSTENCIL
graphtec 60 v3 90hl
I have no idea what has happened... I moved my cutter and set it all up again and everything was working fine until i forgot to plug my USB cord to the computer... plugged it in and nothing so i restarted everything and then I get this  60 v3 90hl on my display screen.. i tried to do a RESET and it goes thru and right back to this ...I am soooo stressed and hope it is not the MOTHER BOARD... anyone have any suggestions or help
after trying to turn it off , unplug it and then try again it is time for professional help  - very rarely do we see graphtec problems
That is displaying your current firmware. That comes on when you turn your cutter on.      And your display says GL not HL  like you wrote.  GL is for Graphtec Language for Cutting Master or Graphtec cutting programs...  HL  is for  other cutting softwares like Flexi, Vinyl Master etc.
https://static1.squarespace.com/static/5900b1a3c534a5aa8149a65c/t/59319957db29d63e1c2d53f4/1496422744941/CE5000+Firmware+Instructions.pdf
How to find your CE5000’s current firmware version • Turn the plotter ON, and note the firmware version which will immediately display on your cutter’s LCD screen.
Once you’ve confirmed your current firmware, you may choose the correct firmware update if necessary. If your current firmware is v5.00 or lower, please download v3.9 If your current firmware is v5.00 or higher, please download v6.4 Note: CE5000 with v5.00 or lower will NOT accept v6.4 and vice versa. An error may occur such as “BAD FIRMWARE” or “CHECK SUM ERROR”
Oh I'm not complaining it is just that I have 8000+ files for format into EPS to transition into a new program... as I am not sure sign blazer works with the new CE6000
been told NO then been told YES, then told NO then YES... I'm ready to drink a whole bottle of wine and call it a day
pina coladas - if you have time to go there Barrachina in old san juan has the best ones while clearing your head :)
when you need the strong relief
Piña Colada
  1. Put 1 cup of crushed ice in a blender. ...
  2. Add 1 oz. of coconut cream to the blender. ...
  3. Add 2 oz. of white rum to the blender. ...
  4. Add 3 oz. of pineapple juice to the blender.
  5. Blend the ingredients together. ...
  6. Pour the piña colada into a glass.
  7. Garnish. ...
  8. Finished
