Bekkisc 0 Report post Posted June 14, 2017 I purchased the Table Titan 3 a week ago and have attempted contour cutting. I calibrated the laser and ARMS. When I use the pen mode for the practice sheets, outlines are almost perfect except cut line is slightly closer to image on the right side versus left side. However, when using the 45 degree blade to contour cut multiples in the same file, the first image is almost perfect but gets more off center with each cut as it proceeds. Any suggestions or thoughts on what I may be doing wrong? Thanks for helping! Share this post Link to post Share on other sites
enjoimark 0 Report post Posted May 21, 2018 I have a Titan 3 SE 68" and it does the same thing... did you ever find out how to fix it? Share this post Link to post Share on other sites
