Hi Everyone,
I was wondering if it was possible or not recommended to cut with 2 programs. I was previously using Sign Blazer Elements, but bought a new cutter and now have VinylMaster Cut. I am not familiar with VinylMaster Cut and have all of my other files on SBE. Is there a way to cut from both programs without messing anything up?
Hi there KMC.
Easy solution --  when you are working on a project in SBE, just select everything in the workspace and use EXPORT (as .eps) from the File menu.
These .eps files can now be IMPORTED to VM and you should be good to go.
Yes, you can use as many different cut programs as you want. If you want to cut with SB one time and VM the next that will work just fine. As slice suggests though, when working in SB, I'd suggest saving off your files as EPS that way you can open them in virtually any other cutting program in the future.
On the opposite side of your questions, I once had a large HTV shirt order and was cutting the two colors of HTV on two different cutters at the same time, using Signblazer Elements. It's all in the settings.
