Bigk_54 7 Posted June 1, 2017 So I'm a rookie here, I have an SC 24" and a guy asked me to cut some numbers for his race car. I'm looking at using Oracal 751 (Open to other options as well) but I'm looking for recommendations on speed and pressure that works well on the 751 vinyl. Do I still use a 45* blade? thank you! Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted June 1, 2017 There is not any set in stone numbers, for cutting. Each cutter is different, even the same model It is all trial and error. ..First you have to set your blade correctly, This is how. To start with, you should set your blade depth correctly, by taking the blade holder out of the machine, and firmly cut across a piece of scrap vinyl, you will be cutting. You should only be cutting the vinyl and barely a mark on wax paper backing, Adjust blade to get there, You should barely see or feel the blade tip out of the blade holder. Then put the blade holder back in machine, and use the force of the machine to get there, same results, only cutting the vinyl and barely a mark in wax paper backing. Cut slow until you learn your machine. Share this post Link to post Share on other sites
mb20music 760 Posted June 1, 2017 2 hours ago, Bigk_54 said: So I'm a rookie here, I have an SC 24" and a guy asked me to cut some numbers for his race car. I'm looking at using Oracal 751 (Open to other options as well) but I'm looking for recommendations on speed and pressure that works well on the 751 vinyl. Do I still use a 45* blade? Yes, you only need a 60˚ blade when cutting thick material like cardstock or reflective vinyl and also if you are cutting really small. Yes, go with Oracal 751 for vehicle graphics. Share this post Link to post Share on other sites
Bigk_54 7 Posted June 1, 2017 Awesome thank you for responses! Glad you mentioned small items for 60* blade I must have missed that somewhere Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted June 1, 2017 Many people on here use a 60 degree blade for all sign vinyl. It does not hurt a thing.... I do. I cut large and small detailed designs. I never have problems with cuts. Blades are the same price at my supplier and I can mix 45 and 60 degree in 1 order. 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 2, 2017 same as skeeter here - 60 degree cleancut blades in all the holders Share this post Link to post Share on other sites
Bigk_54 7 Posted June 2, 2017 thanks skeeter and Dakota (cold water home of the Butler Battlegrounds ) 1 Share this post Link to post Share on other sites
Jburns 239 Posted June 2, 2017 I will chime in - I like clean cut blades- as do many others. Ross is a good guy with a quality product. http://www.cleancutblade.com/ edit: and yes- 751 is nice cast material to work with Share this post Link to post Share on other sites
