Pcampo 0 Posted May 23, 2017 I have the us cutter 9x12 swing arm heat press that came in a bundle with the cameo 3. I am having a lot of problems setting the temp. I'm so confused bc I have no idea what PV & SV stand for. Is the pv number my temp or the sv number. When I set the temp the only number that changes is the sv but the pv has the Fahrenheit symbol next to it and it continues to get higher and higher after I set it. I'm ruining shirts & wasting htv. The instructions are no help Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 23, 2017 manual is listed on their sitehttp://www.uscutter.com/static/PDFs/9X12_Swingarm_Doc_8182016.pdf Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 23, 2017 I have not read the manual but if I had to take a guess it would be that the pv is the actual current temp of the platen and the sv is the target temp you want it to heat up to but I would check out the manual Share this post Link to post Share on other sites
Pcampo 0 Posted May 23, 2017 Thanks, I have the manual and it says nothing about pv & sv. It's weird bc the sv number stays the same but the pv continues to rise way higher than I set it for. I guess I will have to call the company bc I'm really confused by it. Thanks for your help!! Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted May 23, 2017 SV: Set temperature PV: Current temperature Page 5 From this user manual http://www.heatpress.cn//downfile/2014060610385922621.pdf Share this post Link to post Share on other sites
