Pcampo
9x12 us cutter heat press help
5 posts in this topic
I have the us cutter 9x12 swing arm heat press that came in a bundle with the cameo 3. I am having a lot of problems setting the temp. I'm so confused bc I have no idea what PV & SV stand for. Is the pv number my temp or the sv number. When I set the temp the only number that changes is the sv but the pv has the Fahrenheit symbol next to it and it continues to get higher and higher after I set it. I'm ruining shirts & wasting htv. The instructions are no help
I have not read the manual but if I had to take a guess it would be that the pv is the actual current temp of the platen and the sv is the target temp you want it to heat up to but I would check out the manual
Thanks, I have the manual and it says nothing about pv & sv. It's weird bc the sv number stays the same but the pv continues to rise way higher than I set it for. I guess I will have to call the company bc I'm really confused by it. Thanks for your help!!
