The Hanzo 0 Posted May 7, 2017 is there any software out there compatible with a vevor VV375 cutter. artcut came with it and i cant even use the images that came with disk. also the image tracing is sub par. the machine cuts well just cant find anything that will play with it..HElp! Share this post Link to post Share on other sites
Jburns 239 Posted May 7, 2017 Boy, that really looks like an MH series cutter. You can try and download signblazer, ( links on this site) - and / or see if an MH series driver will run it. maybe someone else can chime in, who has experience. Share this post Link to post Share on other sites
The Hanzo 0 Posted May 8, 2017 I tried sign cut pro i didnt see vevor as a manu. when it had me link to artcut it made me select hdme or something like that not even a manu. or model# Share this post Link to post Share on other sites
mb20music 760 Posted May 8, 2017 10 hours ago, Jburns said: Boy, that really looks like an MH series cutter. Not even close Share this post Link to post Share on other sites
Jburns 239 Posted May 8, 2017 26 minutes ago, mb20music said: Not even close Hmm- I thought they were similar MH Head VEVOR Head VEVOR pinch rollers MH Pinch Rollers VEVOR Cutter MH Cutter Share this post Link to post Share on other sites
Wildgoose 4,200 Posted May 8, 2017 Try the Seiki driver in SignCut. There are a few others also that operate on a generic code that I bet you can get it to work. With your Artcut software can you import and cut designs that you made elsewhere? You can design for free with Inkscape. 2 Share this post Link to post Share on other sites
The Hanzo 0 Posted May 13, 2017 On 5/8/2017 at 3:18 AM, Wildgoose said: Try the Seiki driver in SignCut. There are a few others also that operate on a generic code that I bet you can get it to work. With your Artcut software can you import and cut designs that you made elsewhere? You can design for free with Inkscape. Thanks man have accomplished alot with inkscape. Makes artcut2009 tolerable. The cutter is easy enough to use and cuts smalls well just kinda screwed with the software that came with it. It will get me through this year as i learn to use the programs better Share this post Link to post Share on other sites
The Hanzo 0 Posted May 13, 2017 how can i import my inkscape images the svg will not work with artcut? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted May 13, 2017 6 minutes ago, The Hanzo said: how can i import my inkscape images the svg will not work with artcut? When you save your files in Inkscape you are given an option to also save in .eps It would be wise to save both .eps and svg, in case you have to alter the design later. As inkscape cannot import .eps files. You should be able to import .eps file in Artcut. Most software can. Share this post Link to post Share on other sites
The Hanzo 0 Posted May 13, 2017 for some reason it wont import as esp Share this post Link to post Share on other sites
The Hanzo 0 Posted May 13, 2017 59 minutes ago, MZ SKEETER said: When you save your files in Inkscape you are given an option to also save in .eps It would be wise to save both .eps and svg, in case you have to alter the design later. As inkscape cannot import .eps files. You should be able to import .eps file in Artcut. Most software can. It turns this image to those lines and artcut does not come close you tracing the image Share this post Link to post Share on other sites
The Hanzo 0 Posted May 13, 2017 On Monday, May 08, 2017 at 3:18 AM, Wildgoose said: Try the Seiki driver in SignCut. There are a few others also that operate on a generic code that I bet you can get it to work. With your Artcut software can you import and cut designs that you made elsewhere? You can design for free with Inkscape. Which other generic drivers can I try for sign cut? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 13, 2017 try the roland pnc 1000 1 Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted May 13, 2017 Inkscape, is a very good tracing program. There are many inkscape tutorials out there. as well as youtube videos. http://goinkscape.com/how-to-vectorize-in-inkscape/ Share this post Link to post Share on other sites
The Hanzo 0 Posted May 13, 2017 I can use ink scape well it's just artcut won't take any of the converted images Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted May 13, 2017 post a couple .eps. files that you have done... How do you know they are good, if you can't import them? Will those files work in other cutting programs? Share this post Link to post Share on other sites
Wildgoose 4,200 Posted May 14, 2017 I have heard Artcut is pretty limited. If you expect to stay on the cutter world long term you would be best served finding a better cutting program. Your cutter is likely a bottom shelf item as well and that too will have a short lifespan if you get beyond the novice stage. Do some research BEFORE you jump into the programs out there. I think you have learned the hard way that cheapest isn't always the best value. there is a literal TON of information here on this forum if you do some digging you can find a lot of opinions on what cutters are the best for certain applications/budgets as well as the programs that run them. If you are planning to stay a hobbyist I would explore all your options with the ArtCut and see if you can find a combination that works. Most cutters come with a pen attachment. If yours didn't you may be able to backyard engineer something with a ball point or a fine tipped felt marker and use some butcher paper to test things out so you aren't wasting vinyl while you search for a working solution. If you have the budget to use SignCut beyond the free trial, they have live free tech support and I am almost positive they can figure you out. You have to contact them via email but they really do a great job with support. I have a $3500 cutter and chose to use SignCut over all the other options out there. I design in Illustrator but you can design in Inkscape too or Corel. 1 Share this post Link to post Share on other sites
The Hanzo 0 Posted May 14, 2017 Yup I'm goin to figure out a way to get sign cut going on my eBay cutter while I can keep it cutting. Here are some shots of what I have done with the artcut. I started down this path to add on my Hydrographics work and the possibilities are endless and I hope to keep on trucking Share this post Link to post Share on other sites
darcshadow 1,625 Posted May 15, 2017 Just a note on Inkscape, yes, it does not import EPS files natively, but with the aid of another program called Ghostscript Inkscape can be made to open EPS. Just do a google search for Inkscape and EPS and you should find the instructions on how to get it setup. Share this post Link to post Share on other sites
The Hanzo 0 Posted June 2, 2017 my trouble is importing inkscpae files to artcut2009 Share this post Link to post Share on other sites
dcbevins 340 Posted June 2, 2017 I think they use the cario engine now and or poppler internally to import eps in Inkscape, (no longer ghostscript.) Maybe you could go Inkscape to pdf, pdf to artcut. Postscrit, .ps might do it. A simple design as eps shouldn't be a problem. You run into problems with eps with advanced effects like transparency or gradients. Maybe you could post one of the eps files that is failing in artcut. We here could take a look for something obvious. Share this post Link to post Share on other sites
signyouup 178 Posted June 2, 2017 During the "save as" you could try restricting it to "Postscript Level 2" in Inkscape. Maybe Artcut is that old? Share this post Link to post Share on other sites
