karelys 0 Posted May 4, 2017 I'm setting up my cutter/vinylmaster up for the first time to use for contour cutting, and after doing the calibration and the test cuts I decided to test it out with a small job. Though everything is lined up correctly, the contour cut wizard is showing the plotter trajectory lines and cutting them. It had done it on the test cut but I had assumed it was part of the test. Any tips in removing this issue? Quote Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 4, 2017 You could probably get more help it you stated which vinyl cutter you were using.. Quote Share this post Link to post Share on other sites
karelys 0 Posted May 4, 2017 6 minutes ago, MZ SKEETER said: You could probably get more help it you stated which vinyl cutter you were using.. Titan 3 68in Quote Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 4, 2017 You have to follow the instructions to the T. Video says Dragoncut, but it is rebranded Vinyl Master https://support.uscutter.com/support/solutions/articles/14000049749-contour-cutting-with-a-titan-3-cutter-vinylmaster-and-flexisign- Video https://support.uscutter.com/support/solutions/articles/14000030671-titan-3-arms-setup-video 1 Quote Share this post Link to post Share on other sites
karelys 0 Posted May 4, 2017 Thank you, I'll give it a try and see Quote Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 4, 2017 Hope it works out for you.. Your welcome. Quote Share this post Link to post Share on other sites
