acook17 0 Posted May 1, 2017 Good morning, I have a Mutoh VJ 1614A, Ripping with Flexiprint, Using 3M 1080 and IJ35 materials. I am using Eco-sol max 2 ink. My problem is when I print my colors are always off. My grey comes out with a pinkish color and when using spot colors they dont print correct at all. I downloaded and installed the correct ICC profiles but it is still the same. Any suggestions on what my next move should be to correct this issue?For reference I also have a VJ 1624, with correct profiles, that does not have these issues. Thanks Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 1, 2017 how long have you used roland ink in your mutoh printer - I didn't even know they had profiles for that ink for the mutoh - news to me Share this post Link to post Share on other sites
customml 0 Posted May 4, 2017 On 5/1/2017 at 7:31 AM, acook17 said: Good morning, I have a Mutoh VJ 1614A, Ripping with Flexiprint, Using 3M 1080 and IJ35 materials. I am using Eco-sol max 2 ink. My problem is when I print my colors are always off. My grey comes out with a pinkish color and when using spot colors they dont print correct at all. I downloaded and installed the correct ICC profiles but it is still the same. Any suggestions on what my next move should be to correct this issue?For reference I also have a VJ 1624, with correct profiles, that does not have these issues. Thanks You are having problems with your print profiles. Ink is ink, and it doesn't matter, we used many different inks on our bulk ink system on our rolands, till we found one that we really like and that lasts for long time outside against outdoor elements. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 4, 2017 from my experience I have to disagree. the solaris ink that came in my original solvent printer colors were way different until profiles adjusted from the factory ink. but I don't use bulk ink and am pretty particular on the prints Share this post Link to post Share on other sites
