Vinylfreaks & Co 0 Posted April 17, 2017 Hi Everyone, i am semi new to the vinyl cutting thing i use to work with it at my old job, but that has sense gone out of business. So My brother and have started a business doing custom stickers and apparel. we purchased a titan cutter second hand not knowing how far we are going to with this. but it came with no instructions. i have it setup but overtime i cut a test with the test botton on the cutter the test has these little like dog ears on it in one side of the inner triangle and another on the bottom of the cutter most cut. is there any way to fix this ? Thanks for the Help Connor Share this post Link to post Share on other sites
Dakotagrafx 7,148 Posted April 17, 2017 try adjusting your offset to get the corners co cut correctly here is the link to manuals and instructions for the titan serieshttps://support.uscutter.com/support/solutions/folders/14000106614 Share this post Link to post Share on other sites
Vinylfreaks & Co 0 Posted April 17, 2017 23 minutes ago, Dakotagrafx said: try adjusting your offset to get the corners co cut correctly here is the link to manuals and instructions for the titan serieshttps://support.uscutter.com/support/solutions/folders/14000106614 thank you for that but it didn't help me fix the problem i applicate the attempt tho. Share this post Link to post Share on other sites
Dakotagrafx 7,148 Posted April 17, 2017 so you are saying changing the offset did nothing one way or the other on the ears? Share this post Link to post Share on other sites
Vinylfreaks & Co 0 Posted April 17, 2017 it doesn't seem so i was on the default setting 0.30 then went to 0.20 and nothing changed. 1 minute ago, Dakotagrafx said: so you are saying changing the offset did nothing one way or the other on the ears? Share this post Link to post Share on other sites
Dakotagrafx 7,148 Posted April 17, 2017 how did you set your blade exposure? Share this post Link to post Share on other sites
Vinylfreaks & Co 0 Posted April 17, 2017 i also don't know if the setting are changing when i change it on the computer to the cutter is there anyway to let if they have actually changed ? Share this post Link to post Share on other sites
Dakotagrafx 7,148 Posted April 17, 2017 been while since I owned a titan and the reason I directed you to the instructions from uscutter specific to your cutter - as I recall I set it on the cutter . .. the blade exposure has nothing to do with settings on the cutter nor the computer can you post a picture of what it is cutting? Share this post Link to post Share on other sites
Vinylfreaks & Co 0 Posted April 17, 2017 1 minute ago, Dakotagrafx said: how did you set your blade exposure? do you mean how far does it stick out of the blade holder ? Share this post Link to post Share on other sites
Dakotagrafx 7,148 Posted April 17, 2017 from our friend skeeter:To start with, you should set your blade depth correctly, by taking the blade holder out of the machine, and firmly cut across a piece of scrap vinyl, you will be cutting. You should only be cutting the vinyl and barely a mark on wax paper backing, Adjust blade to get there, Then put the blade holder back in machine, and use the force of the machine to get there, same results, only cutting the vinyl and barely a mark in wax paper backing. Share this post Link to post Share on other sites
Dakotagrafx 7,148 Posted April 17, 2017 when you describe the "dog ears" we have heard that phrase used as meaning uncut bits and also as a distortion of the cut - helps in troubleshooting if we know which we are talking about and part of the reason I requested a picture of what the cut looks like Share this post Link to post Share on other sites
Vinylfreaks & Co 0 Posted April 17, 2017 tried my best with the photo lol Share this post Link to post Share on other sites
Dakotagrafx 7,148 Posted April 17, 2017 that looks more like something you can fix by adding to the OVERCUT in scalp Share this post Link to post Share on other sites
Dakotagrafx 7,148 Posted April 17, 2017 also always prefeed yoru vinyl , do not make the plotter pull off of the roll - from your pictures it appears the corners are slightly rounded so offset may be off and I would only adjust .05 one way or the other at a time till the corners are perfectly square after you fix the current issue Share this post Link to post Share on other sites
Dakotagrafx 7,148 Posted April 17, 2017 I am betting you had the blade way further out than recommended which also affects the corners Share this post Link to post Share on other sites
Vinylfreaks & Co 0 Posted April 17, 2017 i tried or what i thought was the half the credit card depth. heres a video IMG_4056.MOV Share this post Link to post Share on other sites
Dakotagrafx 7,148 Posted April 17, 2017 that is absolutely wrong - follow the directions I gave above Share this post Link to post Share on other sites
Dakotagrafx 7,148 Posted April 17, 2017 and I can see from your video the overcut is not enough - not offset but overcut Share this post Link to post Share on other sites
Dakotagrafx 7,148 Posted April 17, 2017 having too much blade exposure also makes this problem worse Share this post Link to post Share on other sites
Vinylfreaks & Co 0 Posted April 17, 2017 what should that be because its set to default which on here is 1.00mm Share this post Link to post Share on other sites
Dakotagrafx 7,148 Posted April 17, 2017 not sure as I use a servo motor cutter that doesn't have that problem but if it were me after setting my blade as described in the 8th post down I would try doubling the overcut and try that . . . I don't do metric or macs Nor scalp for that matter Share this post Link to post Share on other sites
Vinylfreaks & Co 0 Posted April 17, 2017 1 minute ago, Dakotagrafx said: not sure as I use a servo motor cutter that doesn't have that problem but if it were me after setting my blade as described in the 8th post down I would try doubling the overcut and try that . . . I don't do metric or macs Nor scalp for that matter lol i use 2 of those Share this post Link to post Share on other sites
Dakotagrafx 7,148 Posted April 17, 2017 set blade properly - add to the overcut and you should be in business Share this post Link to post Share on other sites
Vinylfreaks & Co 0 Posted April 17, 2017 i will say it definitely better but not completely gone IMG_4058.MOV Share this post Link to post Share on other sites
Dakotagrafx 7,148 Posted April 17, 2017 ummmm - then add some more overcut Share this post Link to post Share on other sites
