Diamond Cuts 0 Posted April 15, 2017 What is the issue with this!? My set up MacBook Pro, Sure Cuts A Lot 4, USB connection, 53 inch SC Cutter. When I'm trying to cut this 34 x 17 inch sign either it takes a lonnngggg time to send to the cutter which I imagine it freezes because it does not advance in the status bar passed like 5% and I end up force quitting or it will eventually send and only cut half of the design. It will cut 8.5 x 11 designs fast and no issues at all. I tried making a yard sign 18 x 24 and it's just freezing while trying to send to cutter. This is frustrating and I've been trying to get this resolved for hours and days!! Contacted support from US Cutter and Craftedge and no response yet!! Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 15, 2017 It is always best to either use a serial connection or a Tripplite Keyspan Adapter (that is the brand name). on a value cutter.. They provide a much better flow of data. The value cutters have a cheap usb chip..Some people have no problems using usb,, while others fight with it like you are. Also keep in mind that the SC cutters have limited memory, and make sure that you have the stand grounded good to the cutter. Share this post Link to post Share on other sites
Diamond Cuts 0 Posted April 15, 2017 Thanks for your reply. I will try to find out where to purchase the Tripplite Keyspan Adapter. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 15, 2017 This is what you are wanting. Prices vary by seller. http://www.ebay.com/itm/Tripp-Lite-Keyspan-High-Speed-USB-to-Serial-Adapter-PC-Mac-USA-19HS-New-/291946944843?hash=item43f964d94b:g:INAAAOSwB09YL36g Share this post Link to post Share on other sites
Diamond Cuts 0 Posted April 15, 2017 Thanks! Will order this and post my updates. (Fingers Crossed) Share this post Link to post Share on other sites
Diamond Cuts 0 Posted April 16, 2017 I ordered it through Amazon and installed required drivers and SCAL is recognizing but it's still doing the same thing. I have 8GB of ram on my MAC and an SSD drive. Any other ideas? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 16, 2017 Can you please show photos how you have the cables connected from your computer to your vinyl cutter. Also can you post the file you are trying to cut.? Have you tired using a different cutting software? Share this post Link to post Share on other sites
