MAYA25 0 Posted April 7, 2017 INGLES: Hi, I have a problem with MH 721-MK2 cutting plotter What happens is that I do the test on vinyl, the star sells me distorted, try changing the blades, try to see a video I saw in this forum, opening the box and adjusting the golden layer and still did not get the results expected, Les I attach a photograph of how you are cutting the star, I hope you help me please I am desperate. HELP Hola que tal tengo un problema con plotter de corte MH 721-MK2 Lo que pasa es que al hacer el test en vinil, la estrella me sale distorsionada, intente cambiando de cuchillas, intente viendo un vídeo que vi en este foro, abriendo la caja y ajustando la tuerca dorada y aun así no conseguí los resultados esperados, les adjunto una fotografía de como esta cortando la estrella, espero me ayuden por favor estoy desesperado. AYUDA Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 7, 2017 as some of the angels cut are correct I am going to rule out offset so then we look to something moving that shouldn't be - first are the pinch rollers tight so the vinyl is feeding correctly? second is the carriage rollers all on the track as they should be as they do sometime come off during shipping, third do not make the plotter pull the vinyl off of the roll always prefeed the vinyl. fourth check the knurl rollers to make sure the set screws on them are tight the the knurl rollers are secure on the shaft they are mounted to Share this post Link to post Share on other sites
MAYA25 0 Posted April 7, 2017 Verifique los Rodillos, Creo Que El rodillo Hace 1 hora, Dakotagrafx dijo: Como algunos adj de los Ángeles Corte hijo correctas voy a descartar compensado por Lo Que then Miramos una Algo que Se Mueve Que No deberia ser - En Primer Lugar hijo los Rodillos de pressure apretada por Lo Que el vinilo this Alimentando correctamente? La Segunda Es Que Los Rodillos De Transporte Todos en la pista de Como ya Dębe Ser Que es ALGÚN Momento se desprenden Durante el transporte, la tercera ninguna Hacen el plotter de neumáticos del Vinilo del rollo de siempre PREFEED el vinilo. Cuarto comprobar v Los Rodillos de moleteado para asegurarse de Que los tornillos de Fijación de Ellos hijo apretados los Rodillos de moleteado hijo los seguros en el eje Que se montan una Creo Que El rodillo moleteado this Un poco flojo del Lado Donde se Conecta a la corriente la maquina, te digo ESTO Por Que Al Momento de tocarlo Como Que se sube y baja Como Si algo estuviese flojo, es correcto ESE movimiento? Si No Es Así Como podria Solucionar ESE error? Creo que el rodillo moleteado es un poco floja desde el lado en el que el aparato está conectado a la corriente, te digo esto porque en el momento de tocar las cosas como sube y baja como si algo estaba suelto, es que el movimiento correcto? Si no es así ¿cómo podrías arreglar ese error? Share this post Link to post Share on other sites
MAYA25 0 Posted April 7, 2017 1 hour ago, Dakotagrafx said: as some of the angels cut are correct I am going to rule out offset so then we look to something moving that shouldn't be - first are the pinch rollers tight so the vinyl is feeding correctly? second is the carriage rollers all on the track as they should be as they do sometime come off during shipping, third do not make the plotter pull the vinyl off of the roll always prefeed the vinyl. fourth check the knurl rollers to make sure the set screws on them are tight the the knurl rollers are secure on the shaft they are mounted to video-1491537696.mp4 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 7, 2017 I would take the side panels off and investigate that - never seen one move like that Share this post Link to post Share on other sites
MAYA25 0 Posted April 9, 2017 On 7/4/2017 at 0:08 AM, Dakotagrafx said: I would take the side panels off and investigate that - never seen one move like that Hey!! Encontré el problema, destape la parte lateral de la maquina y note que la banda estaba un poco floja así que procedí a sacar la tapa de abajo y verifique que pasaba y resulta que el perno que sostiene al rodillo la base de color negra estaba rota y la pude reparar colocando un pegamento muy fuerte a presión con el perno y las tuercas y ahora trabajar muy bien, no se hasta cuando pero esperemos que dure mucho tiempo mas. SALUDOS. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 9, 2017 10 minutes ago, MAYA25 said: Hey!! Encontré el problema, destape la parte lateral de la maquina y note que la banda estaba un poco floja así que procedí a sacar la tapa de abajo y verifique que pasaba y resulta que el perno que sostiene al rodillo la base de color negra estaba rota y la pude reparar colocando un pegamento muy fuerte a presión con el perno y las tuercas y ahora trabajar muy bien, no se hasta cuando pero esperemos que dure mucho tiempo mas. SALUDOS. Share this post Link to post Share on other sites
