printmore559 2 Posted March 29, 2017 Just purchased a graphtec ce 6000-60 i own a mac i downloaded graphtec studio and plug in for adobe i have this 2x4 inch eps file which im trying to cut and i have others with the same issuesits just not cutting the small details look at the e on USED CARS on Martinez and the cut outs on the o,r,a don't even cut out correctly seems like it can't handle the curves. 45 degree blade i tried slowing it down the last pic is the actual eps file pic its clean . please help Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 29, 2017 so what are your settings.. What is the blade offset? It should be zero. How did you set your blade depth? I have heard not to use condition 1, as it is for pen.. I have never used Graphtec Studio...Try a different software, even a trial like Signcut and see if it is the software. Make sure pinch rollers are over the bottom grit rollers, so the vinyl is feeding right. Share this post Link to post Share on other sites
Pyro Nemesis 4 Posted March 29, 2017 2 hours ago, MZ SKEETER said: so what are your settings.. What is the blade offset? It should be zero. How did you set your blade depth? I have heard not to use condition 1, as it is for pen.. I have never used Graphtec Studio...Try a different software, even a trial like Signcut and see if it is the software. Make sure pinch rollers are over the bottom grit rollers, so the vinyl is feeding right. Interesting observation on the condition! I have always been using #1 but upon reading your comment I went to view some of the videos on graphtec studios site and noticed #2 always being the one they have selected. I have always had #2 set as my pen so I am certainly going to try changing this to see if it helps with my tails and nicks! Share this post Link to post Share on other sites
printmore559 2 Posted March 30, 2017 Mz Skeeter, Setting are set at Offset 0, Speed 20, Acceleration 1 Cutforce 15, As for the blade depth my buddy who has a graphtec came and adjusted it. Pinch rollers are good . Man this is frustrating for having a new machine Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 30, 2017 I'm not a mac person but just for grins why don't you try the trial version of signcut for mac and see if that cuts any differenthttp://www.signcutpro.com/try-signcut/ Share this post Link to post Share on other sites
printmore559 2 Posted April 1, 2017 Fixed the problem!!!!! Mz skeeter , Dakotagrafx, So i get the crazy idea of restoring the cutter to factory settings and that did the trick i guess some sort of setting. anyways I'm cutting with my cutter !! perfect timing i need to cut 3 jobs a total of 1000 decals 2x4 inches. thank you all!! 2 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 1, 2017 Great glad you got it fixed. Share this post Link to post Share on other sites
