rastoma
Not possible to use cut sheets on LPII?
I have rolls of vinyl and flock.  But I'm trying to use smaller sheets, around a 12"x12" sheet of flock to try and make rhinestone templates with.
The pressure rollers cause dents in just regular vinyl (the vinyl that USCutter included in my package) but when I try a sheet of flock one side will inevitably get pushed out.  So if I'm not staring at it then it one side will get pushed out and the flock will go back and forth under just one of the rollers and the blade will start cutting on the white strip on the cutter itself, which looks like it broke the tip of the 60 deg blade.
So can I only run items that are on a roll through this machine?
And can that white strip be replaced?
