irjaren
Schien
Hello
I am a beginner at cutting vinyl. Currently using a 25" SC cutter; 60 degree roland blade; mac book pro. Currently using Schein Chrome and I have noticed it on the oracal 651 stickers I have cut. My issue is the cuts dont seem to be clean. I can see little dots around the stickers almost like the machine is stuttering every 1/16 of an inch.
Thank you for the help
10 hours ago, Dakotagrafx said:
9 out of 10 new users that report that have way too much blade exposure
thank you for the reply!
I messed with the blade exposure and seem to be having the same effect. hopefully this picture shows exactly what I am trying to describe. Maybe this is just normal?
that is not normal -
That can also be caused by a broken blade tip
here are some directions for setting blade depth from our friend skeeter
When I cut Avery chrome, I don't change my blade depth going from Oracal 651 to chrome.. I only change my force up a couple notches as it is a thicker polyester product..   Use the directions above Dakotagrafx listed to set your blade depth.
Also might want to try decreasing pressure
I'm thinking broken blade tip.
I have had that happen with reflective vinyl, which wreaks havoc with carbide blades. That chrome stuff is similar, I imagine.
Alternatively, the blade is not spinning freely inside the holder bearing. Take it all apart, add a drop of sewing machine oil.
Also, perhaps the carriage is not sitting properly on the guide rails --  check that to verify.
