arty-rc 719 Posted February 28, 2017 Hi all, This might have been asked before but is there any easy way to convert SBE files into eps files? I have been exporting them into a separate folder one by one as eps files but it's slow going. Any ideas? Thanks. Share this post Link to post Share on other sites
darcshadow 1,626 Posted February 28, 2017 Nope, what you're doing is the only way to do it. Share this post Link to post Share on other sites
arty-rc 719 Posted February 28, 2017 45 minutes ago, darcshadow said: Nope, what you're doing is the only way to do it. Thanks DSD. That's what I was thinking. Should be done by the end of the year LOL. Share this post Link to post Share on other sites
slice&dice 2,450 Posted February 28, 2017 Just out of curiosity, why would you require all your old files to be converted? I have tons of SBD files, and over the years, I recall only going back into them a few times (for customers who want a re-order). Once a job is done, I file it away into a folder called "DONE and GONE" Share this post Link to post Share on other sites
mb20music 760 Posted February 28, 2017 1 hour ago, slice&dice said: Just out of curiosity, why would you require all your old files to be converted? Well, probably because he is upgrading to newer software that doesn't open .sbd files! lol Share this post Link to post Share on other sites
slice&dice 2,450 Posted February 28, 2017 3 minutes ago, mb20music said: Well, probably because he is upgrading to newer software that doesn't open .sbd files! lol OK, I get that, but why ALL of them? Share this post Link to post Share on other sites
arty-rc 719 Posted February 28, 2017 Windows 10 has been doing some strange things lately. When I plugged in my "programs" flash drive the Defender program detected my SBE installs as malware and removed them from the flash drive. Luckily I had them saved to other drives and burned some Cd's. Just don't want to take a chance that Defender tries to remove the files also. may be overkill but you never know. Share this post Link to post Share on other sites
slice&dice 2,450 Posted February 28, 2017 "sees SBE installs as malware " ---- yep, that'll happen, because the "reminder screens" which are supposed to load at startup have been disabled with internal code cracking and that appears as a problem to antivirus detection. Anyway, yes, what you are describing is truly overkill. The SBD files are never removed by uninstallations or re-installation. Share this post Link to post Share on other sites
arty-rc 719 Posted March 1, 2017 OK, but is there a chance that the Defender might see the installed SBE program itself as malware and remove it. If that should happen, how would we convert the SBD files for use in other cutting programs? Share this post Link to post Share on other sites
slice&dice 2,450 Posted March 1, 2017 3 hours ago, arty-rc said: OK, but is there a chance that the Defender might see the installed SBE program itself as malware and remove it? No. Share this post Link to post Share on other sites
